View unanswered posts | View active topics It is currently September 3rd, 2010, 4:26 pm
Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 On-board air write-up using stock A/C pump
Post On-board air write-up using stock A/C pump
SO I figured I won't be fixing my A/C since I took out the condensor to fit my tranny cooler. I also figured out that when I do my york, I'll have to run a tank and air lines and filters and oilers and wiring. So why not do that stuff now and use the stock A/C pump until I get the york in? BRILLIANT!
Following Dblue's write-up on WT4X4 (http://www.wt4x4.net/tech/onboardair.htm), I decided to go for it and do the damn thing. This will be a "after the fact" write up since I didn't have a camera the whole time I was doing it. It's fairly easy though.
First I took the manifold off the back of the pump and cut the lines at a nice convienent spot where my pipe cutter would work.
I then figured out which one was suction and which was outgoing. The bigger of the two is incoming
Then I bought a bunch of fittings and hose and clamps and a full compressor air conditioning set from harbor frieght for $20. I got a ricer air filter for a breather for my incoming filter.
I then directly wired the pump to a toggle switch in the cab
I then mounted up an air tank under the bed. It's 7 gallons and it costs about $20.
And yes I did make the tank mounting bracket out of some scrap metal I had laying around. I put some silicone weather stripping unbetween the tank and the bracket to keep it from squeeking as I drive down the road.
I then ran air lines to the front and the back of the bronco.
The last thing I want to do now is get a gauge for inside the cab so I know when the tank is full. I'll update you when I get to that.
Julians #2 fan behind my Dad. Much love for our new Friend.
September 22nd, 2008, 5:12 pm
Post Re: On-board air write-up using stock A/C pump
Damn rich! Wanna do it for my bronco??? :jewish:
Wolfpack Member #2
I am Chief Ponce, Master and Commander of all Chipmunks.
September 22nd, 2008, 8:57 pm
It's easy enough to where I could help or just give you a complete rundown of what would be needed saving you some headache.
September 22nd, 2008, 10:03 pm
Looks great Rich, I wanna see some tests though! How long does it take to fill a tire from 12 to 35 PSI?
September 24th, 2008, 11:15 am
That's a tricky test to just do one tire. It has a tank so if the tank is full, it should take around a minute or so at the most. Empty, it's filling the tires and the tank making it worse. The beuty is that I can disconnect the line going to the tank so I can use a full tank on the rear and then disconnect it so i'm only filling the tires. Once the tires are full, re-connect the tank and fill it up on the drive out. I can do a no tank 1 tire fill and give you that time. :shrug:
September 24th, 2008, 2:45 pm
Online
If you hold the throttle it will fill much faster!
Lifted '89 Ford Bronco 5spd SAS- Representing Ford's I6 Stump Pullers! :thumb:
Keep our trails open! • "Real wheelers are built, not bought." • KI6ZFQ
September 24th, 2008, 4:10 pm
yes.
September 24th, 2008, 4:55 pm
Id actually really like that number.
September 24th, 2008, 9:21 pm
update!
Iv'e since ditched the A/C pump and went with a york. The tank was doing great until the last snow trip where I hit a couple of "bumps" and sent my rear pinion into the tank itself. Time to replace it or maybe with some luck, modify and repair it.
Moral of the story, suspension travel beats good tank mount location everytime.
March 22nd, 2010, 8:25 pm
I still have a few of these SCBA tanks $5 each
March 22nd, 2010, 8:27 pm
I think i'm going to try and have my work do a "clearence" indent on the tank by cutting out a section and welding in an inverted section allowing more room. That tanks already mounted, plumbed and a good size. I don't want to have to do to much to make it work.
Also on the update;
Harbor freight filter and oiler sucked, don't bother. Stock A/C pump worked ok but the york is much better.
March 22nd, 2010, 8:48 pm
March 28th, 2010, 11:47 am
So whats the plan do fix your Tanque De Aire?
March 28th, 2010, 3:18 pm
turns out its steel. A little cut and hump should give me the clearence needed.
March 28th, 2010, 4:12 pm
This is an awesome idea! I just took out my whole AC system but i think the compressor is headed back in... Thanks for posting this :thumb:
Junior Bronco Build
May 1st, 2010, 8:03 pm
