View unanswered posts | View active topics It is currently June 17th, 2021, 7:16 pm
Reply to topic  [ 147 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10
 1356 / 1356 doubler
Post Re: 1356 / 1356 doubler
I wonder if we could get a deal on 3? Lol
My only problem is that mine is the shortest version 92 and older. If I re-gear I will have to spend again. I am going to look for a strap type in the PnP and modify for u-bolts. If I can't find one then I will buy from there.
BTW, that is what they are doing to these, they did not start life as a U-bolt.
They don't seem to make a 92 u-bolt aftermarket either. :cry:
July 23rd, 2015, 7:14 am
I too have the short version :(
July 23rd, 2015, 8:15 am
I had to go to strap, Spicer doesn't make u bolt anymore. People were over tightening them. Our local shop Extreme Off Road has a rock buggy with straps, he says they do fine. It's 460, 60 front, 70 rear, 47" tires. I've been on Dusy with him a couple times, it does great. He's in our club too.
July 23rd, 2015, 8:19 am
why not machine a cap to take the place of the straps? this would give much better support to the u joint and likely stronger too.
July 23rd, 2015, 8:21 am
I like the idea behind the stronger u bolt style but id also rather break straps as opposed to a drive shaft or u joint. I dont know maybe the yoke could break but i carry extra straps... :shrug:
July 23rd, 2015, 8:31 am
here you go http://www.justdifferentials.com/Billet ... 8x-bil.htm
July 23rd, 2015, 11:50 am
Hmmmm
July 23rd, 2015, 1:12 pm
I like that option.
July 23rd, 2015, 2:28 pm
one more option keeps poping up when I search. seems that they make lots of 1410 yokes in u-bolt style and 1350 to 1410 u-joints are everywhere.... hhhhmmmm
there is also these, should be pretty strong. book marking
stearling short yoke with u-bolt
https://www.yukongear.com/PartsList.asp ... nion+Yokes
http://www.jegs.com/i/Strange+Engineeri ... fgodu8wEsQ
http://www.finditparts.com/products/597 ... fgod-OYNpw
http://www.dennysdriveshaft.com/p1219_1 ... _1992.html
July 23rd, 2015, 3:36 pm
That company does make a short yoke. I was going to past the link then I saw what you posted :mrgreen:
July 23rd, 2015, 5:56 pm
bonanza today at pnp. short 1350 yokes were everywhere. picked up two so I have a spare but now have to see about converting them to u-bolt or find a better strap. I'm going to ask Steve at SB drive line and see what he says.
Also picked up a spare flange to play with, a couple short filler necks from a dump truck, and a spare clutch slave and hydrolic line
July 26th, 2015, 9:14 pm
forgot to say that I had a conversation with Steve at SB driveline about the strap u-joint. It turns out that the problem with the u-joint popping through he straps is primarily a Chevy thing. He recommended I change out the for torx type screws for an aftermarket hex head or even better drill them through completely and use a grade 8 allen bolt with a nut. The common failure for a ford strap u-joint is when the driveshaft angle gets tight enough to contact the strap bolt head and breaks it off. That said I have spare yoke as well.
July 31st, 2015, 11:59 am
