View unanswered posts | View active topics It is currently June 17th, 2021, 6:53 pm
Reply to topic  [ 142 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 project batty
Post Re: project batty
jasonhughes2009 wrote:
Thinking just a 383. Nothing too crazy. I'd like to go manual. Probably just the m5 and see if I can find a twin disc clutch.
M5OD? I have one in my truck I'll pull out if you want to buy it.
I thought you were running the zf in yours or did the case finally crack? I'll think about it I just found out one of the new guys we hired is selling his 79 f150 with a bored 460 for 1600 so I might buy that and put the bronco project on hold for a month or two. Just gotta get pictures of it first.
June 4th, 2015, 4:44 pm
I mean this in the nicest way possible, but why on earth would you put an M5OD behind a built 383 stroker? Notice Ford didn't even use that trans behind the stock 302 or 351? Do the ZF and be done with it!
June 5th, 2015, 7:58 am
I was thinking about how many cases I've seen brake and the repair bill afterwards. Then I remember today it was only the diesels due to the vibration. So yes. Zf it will be.
June 5th, 2015, 9:56 pm
Going to check out and most likely buy the 79 this weekend. Pretty excited for it going to have some small work that needs to be done but nothing too major.
Driving a mazda protege sucks but man is it good on gas.
July 14th, 2015, 10:04 pm
You're buying a 79 Bronco? What are you planning to do with it?
July 15th, 2015, 7:01 am
79 f150 high boy. Daily driver / light trails/ tow rig for the bronco. Debating on building up a 6.9 idi for it or maybe find an earlier isbg to throw in. 460 right now in it and c6 auto
July 15th, 2015, 8:51 am
Well it didn't run like the dbag said. So got it to the shop on a trailer. Pics to come. Gotta figure out what's up with the wiring. No power in the cab with a new battery. Definitely a good buy but gonna need a little work. Not sure if I should get classic plates or not. On a side note the 9 inch on the bko took a dump. Haven't had time to pull the third member and figure out if it's just the gears or if the locker pooped itself
August 26th, 2015, 11:45 pm
Got the 79 cranking. No fire though. Wire broken inside of the dizzy going into the magnetic pickup
September 3rd, 2015, 9:11 am
Got the hei dizzy. Tried to install and turns out I needed to get a bevel casted water outlet. Got that and a new thermostat. Hopefully get it to sputter tonight.
September 15th, 2015, 8:42 pm
There's always a lot of little things that really slow the progress on projects
September 15th, 2015, 8:57 pm
Yeah. Too be expected though. Gotta get a new radiator. Went to drain the coolant and there was nothing to drain. Pressure tested and air comes out of the side of the rad
September 15th, 2015, 10:32 pm
At least your making progress! Keep at it! Let us know when we're having the work party for the one ton SAS :mrgreen:
September 16th, 2015, 8:18 am
May wonton it may not. Don't really see a need. Now the bronco... that may be happening. Have to wait till we buy a house though. 5
September 16th, 2015, 10:37 pm
Did the 3g swap the other night. No longer blowing fuses but need to pull the water pump and timing cover to drill and extract a bolt for the vbelt bracket. Godamnit... I love how cheap everything is for this truck though.
September 25th, 2015, 10:15 pm
I have a ton of success welding nuts to broken studs. ... might want to try it first
September 26th, 2015, 2:32 pm
