View unanswered posts | View active topics It is currently June 17th, 2021, 5:33 pm
Reply to topic  [ 15 posts ]
 My sons Scout
Post My sons Scout
Ryan got this about four years ago already built. Recently he changed the clutches in both Power Loks, he's saving up for new tires too.
February 1st, 2016, 1:53 pm
Post Re: My sons Scout
He did most of the work himself, I helped him through it. One of the front inner wheel bearings was really stuck on the spindle, ended up breaking the cage off and ruining the seal in the process.
February 1st, 2016, 2:02 pm
Cool Scout, I've always loved the 80s. Does it have the 304 or the half-a-304-inline-4 or something else entirely? Is there a body lift on there or just a lot of suspension lift? Looks a little high for the tire size.
February 2nd, 2016, 7:57 am
This is how we brought it home four years ago.
Started life as a 1961 Scout
67 Scout body
345 V8 from 75 Scout II
T19 granny from 78 Scout II
Dana 300 from 1980 Scout II
Dana 44 front from 3/4 ton Chevy
Dana 60 rear from 3/4 ton Chevy
Power loc front and rear 4.10 ring & pinion
Power steering from Scout II
Custom full roll cage
Racing seats with 5 point harness
Custom front bumper with Warn electric winch
Custom rear bumper with swing away tire carrier,high lift,gas can,axe and shovel
Double u joints in steering shaft instead of rag joint
CB
Stereo
Roof rack
3 fuel tanks with a total of 40 gallon capacity
Headers
Dual Optima batteries with marine 4 position switch
Buggy springs rear(military wrap),with double jointed shackles(whatever they are called)
Front springs have military wrap
Shackle reversal front
Rag doors
Bikini top
35" Pro Comp tires(10 years old)
Custom drive shafts,both with CV joints
Rock sliders with step
Electric wiper drivers side only
Two fully charged fire extinguishers
Painless wiring
Line lock
Can't remember any more right now
All his IH/wheeling stuff came with it.
Spare 345 V8 with 120 compression on all cylinders that has been stored inside
12" clutch in good condition
York to convert to compressor
Box full of manuals
set of 345 heads
IH air horn
Flex plate for automatic
carb(needs rebuild)
seats & covers
windshield frame painted yellow
Engine stand
Engine lifting plate(bolts to intake manifold where carb goes)
5 gallon steel water can
spare drive shafts and tie rod
PTO(for 4 speed)
And on & on,I didn't look at all of it
February 2nd, 2016, 9:20 am
Some more stuff we did. The prior owner had a home made drag link going into a tapered hole in the tie rod with a straight bolt, he left it loose so it would'nt bind. Doh! This made for sloppy steering. Knuckles were already flat top, we had the passenger side one machined flat on top, drilled and tapped. Then bolted on the arms, they have spacers welded to the bottom of them. We need to reposition the spring hangers though, they're too high in the front. When it flexes, the drag link will hang up on the spring. We removed the clamp on the spring pack right by the drag link.
February 4th, 2016, 11:39 pm
The alternator quit working, and we replaced it. It had a Saginaw power steering pump in a bracket with only one bolt into the engine, couldn't keep the belt tight. Can't use a Scout II or D Series bracket, it puts the pump too far over. There isn't enough room in the earlier engine compartments. So we used a TRW pump, used from 69 to 73. We were able to put this in a stock bracket that let us tension the belt good. It's the same thing I have in my truck.
February 4th, 2016, 11:50 pm
Check out that radiator! Cool rig overall.
February 5th, 2016, 8:57 am
Thanks, he's proud of it. You're right about it being high for the tire size, that's how we got it. We can look into it when we rework the spring hangers. Ryan got that radiator, the old one was leaking. They're available for the more common Internationals, not my truck. he's hoping to have it on the trails this season, he got two new tires yesterday. Two more when he can afford them.
February 5th, 2016, 10:01 am
Speaking of money, tell him to start saving money to replace those yellow tops :angel:
February 5th, 2016, 7:02 pm
I don't know what you mean by that, I'm guessing the batteries........
Our annual snow camping trip is next weekend, six IH rigs are going, and probably as many or more non IH. We have a lot of fun.
February 5th, 2016, 10:00 pm
I'm just teasing about optimas reliability. I used to be a fan but they're quality went way downhill about 5-6 years ago. They're just living on reputation at this point.
February 6th, 2016, 8:47 am
Hmmmm. I might just have him get regular batteries, that's what I use.
February 6th, 2016, 9:41 am
Yes the old optimas were great batteries but once they caught a military contract they went to "cheapest bidder mode". I like regular old interstate batteries.
February 6th, 2016, 11:04 am
Thanks for the info, I don't know that we would have paid that much for a battery anyways. That's just what it came with.
Here's pics from when we changed from a 2.62:1 Dana 300 to a 3.15:1 Dana 20. The Dana 300 case had been cracked and welded, and bondo used on the surface that mates against the transmission adapter plate. We didn't know that when we bought it. This took the crawl ratio from 67 to 81.
February 6th, 2016, 11:37 am
This was his first time driving to and from the snow run, I trailered it two years ago. He did pretty good, all four wheels are pulling with the fresh Power Loks.
February 15th, 2016, 9:10 am
