View unanswered posts | View active topics It is currently June 17th, 2021, 5:55 pm
Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
 My 1971 Travelall
Post Re: My 1971 Travelall
I got power from the wire on the regulator that comes on with the key in the run position, and ran it through a coil resistor. Drove it up to Courtright Reservoir, stayed a couple days and came back. About half way up I noticed the amp meter was in the discharge, slightly. Made it up and back fine. Then put a wire from the F on the alternator to the battery, started it and the needle went into the charge. So I thought it was the regulator, I already had a new one. Changed it and moved the power source for the coil to the ignition switch, started it back up and it's not in the charge. I also checked the alternator, it has power on one post. So now I'm thinking the power from the F terminal isn't going where it's supposed to go. If it was going to the battery, it would show charge. ???
Travelall ran pretty good, no engine or transfer case leaks. A very slight leak from the transmission drain plug. This transmission is noticeably lower in first gear, and reverse. It's noisier though. It would have been worked harder, coming from a two ton instead of a half ton. It was nice to drive it again after a couple months of it being down.
July 2nd, 2016, 3:45 pm
I went back out and noticed one of the wires in the voltage regulator plug was backed off. I pushed it back in, fired it up and it's charging.
July 2nd, 2016, 8:22 pm
Awesome update. That's a great test drive!
July 3rd, 2016, 6:20 am
Yeah if it can handle that test drive it's ready, huh? I think it was a million degrees when we left the valley, half way up Courtright road everything was drenched. A thunderstorm had just came through. The people we were meeting were sitting in their horse trailer because of the rain and wind.
July 3rd, 2016, 7:40 am
Funny how quick the weather can change up in the mountains huh? Our first year on the Dusy we got rained on the better part of a day.
July 4th, 2016, 2:59 pm
Yeah, and the people in the valley are oblivious to it.
July 4th, 2016, 3:16 pm
Putting a CB on my Travelall, finally.
March 8th, 2017, 8:23 am
I haven't had a CB in my bronco in years... Wanna come do mine :mrgreen:
March 9th, 2017, 9:44 am
Ditto. I have 2 in a box on the shelf.... what happened to us?
March 9th, 2017, 3:02 pm
Ha!
My truck has one, and I've been meaning to put one in the Travelall for years. BTW I didn't get it done yet, I'm back to working on my truck engine. Some progress though.
March 12th, 2017, 9:45 am
Got this engine November 20th.
January 23rd, 2018, 10:16 am
I ran it hanging on the hoist chain. Sounded good, but it had a 40 psi variance in compression. Three valves weren’t sealing, a little was getting by all the rings too.
Replaced rings and did a valve job. Also replaced oil pump, rod bearings, water pump, valve springs, and a few other things.
January 23rd, 2018, 10:42 am
Video after startup.
https://www.youtube.com/watch?v=Qbhi0u8HeX4
January 23rd, 2018, 10:46 am
So what motor is that the 304?
January 25th, 2018, 9:02 am
It’s a 345, probably from late sixties judging by how it’s dressed up. There are indicators.
January 25th, 2018, 9:16 am
