View unanswered posts | View active topics It is currently April 2nd, 2020, 1:49 pm
Reply to topic  [ 172 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
 Ed's loader
Post Re: Ed's loader
I safety wired some bolts on my cross member that we’re notorious for coming loose. Been great ever since! Sometime it’s old school tech that works just fine.
Yeah, I did it with the bolts that hang the transfer case in my truck off the crossmember, they came loose before.
December 14th, 2018, 12:29 pm
https://m.youtube.com/watch?v=iIGz3kaLzhg
I could drive right through the cut logs, but they would be right next to the loader. Did not leave me any wiggle room, I pushed them either side. And took some way down to the end and dumpd them.
https://m.youtube.com/watch?v=CAsW7upPHy0
December 14th, 2018, 3:17 pm
1:14 to 1:25, I pushed the tree that’s parallel on the right. It was centered in the available space. And right before the end you can barely see the remnants of the stump I pushed through, basically it’s wood debris color instead of dirt.
I think the sun would have cooperated better going clockwise. Oh well. I was losing daylight and needed to wrap things up.
https://m.youtube.com/watch?feature=you ... Bud8r1fjVc
December 14th, 2018, 10:56 pm
awesome. That thing is a tank!
December 15th, 2018, 7:04 am
Thanks, it has been a long time coming. Not all done, but at least I got some use out of it. I don’t know that I will do anything else before spring, we’ll see what winter brings.
December 15th, 2018, 8:54 am
I chased the threads with a bottom tap, and tightened the bolts to make sure the length is good. Now I’ll paint the plate for next time, and drill the other plate just in case.
December 25th, 2018, 12:09 pm
Found a blacksmith to straighten the battery cover enough to close all the way.
January 4th, 2019, 12:34 am
I counted 140+ hammers in their shop, various sizes, shapes, and handle lengths.
January 4th, 2019, 12:39 am
The front piece was bent too, they got it pretty straight.
https://m.youtube.com/watch?feature=you ... EKr9-RGRv0
January 4th, 2019, 4:27 am
They used this little furnace to heat the metal.
January 4th, 2019, 4:47 am
That’s pretty cool, I dig the old school fab work.
January 5th, 2019, 10:15 am
Got the battery cover welded back together.
February 9th, 2019, 4:57 pm
Painted the lock plate, used paint from Kimball Midwest. Terex Green.
February 9th, 2019, 5:00 pm
Did a color test spot.
February 12th, 2019, 10:02 pm
