View unanswered posts | View active topics It is currently June 25th, 2021, 1:03 am
Reply to topic  [ 342 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23  Next
 CJ's 1989 K5 Blazer
Post Re: CJ's 1989 K5 Blazer
Sweet, glad you found that loose pitman arm ;) Let me know if you need a hand.
June 21st, 2011, 4:55 pm
When you want to get this done CJ? this week end next week end? Im ready
I have a hot wife & I know how to use her ;)
June 21st, 2011, 10:03 pm
The 1 ton booster and MC was one of the best upgrades I've done in a long ass time, one of those "why didnt I do this sooner!?" moments. I hope you're as pleased as I was. :thumb:
June 22nd, 2011, 11:15 am
Steering box is tight to the frame. Loose pitman arm is as tight as can be. And spacers are put into the leaf pack so the tie rod is no longer binding on the spring (thanks Larry). Truck is steering much better. Now I need to get te truck stopping better. Maybe tomorrow I can pull the master cylinder and brake booster and upgrade to the 1 ton stuff. I will also be adding extended brake lines too.
Also realized I need new seats and new shocks.
August 6th, 2011, 2:50 pm
Nice buddy, good to see you working on this thing.
When you bring it home so you can work on it after work?
August 7th, 2011, 2:45 am
You figure out a way to mount that shim and still get the centering pin to work?
August 7th, 2011, 11:00 pm
I was able to go around the corner to the parts shop and grab some longer pins. Then I just put the Shim inside the leaf pack.
August 8th, 2011, 6:20 am
Got the new master cylinder installed. Pedal already feels way better and I haven't even bleed the brakes yet.
Plans is to replace the front brakelines with the extended brake lines and then bleed them.
Once brakes are bled and driver seat is back in I am going to be hitting up Niagra rim. Next step after that is new shocks.
August 23rd, 2011, 5:13 pm
Wheelin trip! Lets do it!
August 23rd, 2011, 8:44 pm
ITS ALIVE. With help from Ryan I finally got my brakes bled and the blazer stops. I am now ready to wheel.
Next step is to get it flexed out to do some measurements so new shocks.
September 26th, 2011, 4:57 pm
Great to hear! Don't forget, I have shock mounts off my truck..plug and play, just bolt on to the frame and weld some tabs and your good for 14" OF TRAVEL...
76k5 d60 detroit 35 spline, high steer cross over, psc ram assist, corp 14 detroit rear disk brakes, 350 crate ord doubler w/triple stick, alcan front/rear springs, shackle flip, track bar, high angle drive lines full cage, elect fans, 38 KTMs[/b]
September 26th, 2011, 7:25 pm
Sweet. Nice work CJ.
September 27th, 2011, 10:17 am
CJ.... still need these:
CANT BEAT THE "FREE" PRICE........... If you want them. please stop by ASAP and get them...Im cleaning out alotta stuff........
November 30th, 2011, 6:50 pm
So CJ, what needs to get done to get this thing safely drivable again?
April 17th, 2012, 2:22 pm
First need to fix the brakes. Tried to adjust the pedal but it isn't adjustable like justins diagram had shown. Also opened the master cylinder and the front ballast was empty. I also need to flex it out and measure for shocks.
April 17th, 2012, 4:36 pm
