View unanswered posts | View active topics It is currently June 17th, 2021, 6:33 pm
Reply to topic  [ 342 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23
 CJ's 1989 K5 Blazer
Post Re: CJ's 1989 K5 Blazer
Thats awesome. Great work. good little list too.
April 21st, 2013, 8:56 am
We had a productive day indeed. Good to see this thing in good shape and back on the road!
CJ started by having the truck piss ATF all over the driveway
CJ got the case out
Took it apart, cleaned the mating surface and applied a generous amount of RTV
Looks like a transfer case inside
Ready to go
While CJ was transfercasing, I pulled the steering box and started by cleaning up the frame to see what we were working with
The trail repair, not bad at all considering it was done on the con
2 of 4 holes were in bad shape so I started by building up some weld around the trail repair to build a little more strength
Then I hit the frame with a weld through primer to keep things rust free behind the new plate
Also primed the frame braces from the kit with some weld through primer
Action shot!
Welded up!
Painted and ready to go, CJ apparently likes to apply a single HEAVY coat :goodfinger:
From the bottom
The bottom plate welds into this front crossmember which should bring a lot of strength into the whole thing
Front, note the gaps in the weld are intentional. The instructions specify where to weld, I assume the gaps are to allow for a little flex and prevent frame cracking
From the back side of the frame we stacked some thick grade 8 washers behind the factory spacer-thingys. The idea here was to spread the load out a little more and prevent future issues.
This lower left bolt was the worst one. The frame was a little tweaked and it was nearly impossible to weld it from the back side so we stacked a bunch of big thick washers to spread the load out and hopefully keep things together!.
Backside of the frame
Chevy makes all the bolts real easy to get to
Bottom shot
Box in and ready to go!
Trucks looking good and driving good. CJ, tell us how good it feels to get back on the road in that thing!?
April 21st, 2013, 8:07 pm
Very nice!
April 21st, 2013, 8:15 pm
Cool! That was one of the best trail repairs I've seen. I forgot that guys name but he sure could weld!
April 21st, 2013, 9:42 pm
Thanks Dan for all the help and the pictures. The guys name was John and he's from the east bay.
April 22nd, 2013, 6:15 am
With a newly rebuilt transmission. The blazer lives again.
January 20th, 2017, 4:00 pm
Yeeeeaaaaaa. :thumb: :thumb:
January 20th, 2017, 9:03 pm
Amazing! Can't wait to see it on the trail.
January 20th, 2017, 9:19 pm
I was reading over the pictures above and thinking how sunny it was, then to realize that was 4 years ago! Just posting it drives was anti clamatic, where is the action shot?!
Btw congrats on getting it going again! ;)
January 21st, 2017, 11:00 am
Latest update. Located a 4 core aluminum radiator for a reasonable price. So I ordered and installed it. With the larger size of the radiator I needed to figure out a way of mounting it. I was able to reuse the existing bracket with a slight modification. I cut off where the original radiator was held and welded on a additional brackets to hold the radiator.
With the first snag taken care of I went to install the fan shroud. Unfortunately it did not line up anymore. So I used my trusty Dremel tool and opened up the radiator shroud a little to allow the fan to spin freely. I then temporarily zip tied it into place so I can go wheel this weekend.
Next step is to permanently mount the fan shroud or upgrade to e fans.
April 12th, 2018, 11:42 am
Excited to see this thing back on the trails, been way too long!
April 13th, 2018, 9:33 pm
not that long since hollister... you just don't go out with us anymore.
April 13th, 2018, 10:20 pm
