View unanswered posts | View active topics It is currently February 19th, 2019, 4:28 am
Reply to topic  [ 160 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
 What do you carry with you on a trip?
Post Re: What do you carry with you on a trip?
ahhh i forgot to say you gotta have a few 30 packs, bottle of jager, and bottle of jim beam
crawl it bitch!!!!
August 27th, 2009, 11:24 am
oh man last time I did hard drink on the con I lost a hat! It was over a year later when I returned and looked for said hat to find it had survived an entire winter on the con! :lol:
August 27th, 2009, 11:46 am
bump for Brendon
February 17th, 2010, 9:28 am
It's not on my first page list just yet, but for long distance trips (Rubicon, Fordyce, etc...) I also carry more electronics that could potentially disable my EFI engine like a spare computer, TPS, etc...
February 17th, 2010, 10:49 am
I carry a Power Probe 3 with me most of the time, specially on long trips. Use it at work with electrical diag. http://www.powerprobe.com/powerprobe/Home.html
Did a ZJ V8 tie rod and all ends swap on the TJ, so for long trips I will just carry the stock tie rod with me now.
Cam Cam
February 28th, 2010, 9:00 am
(power probe) lol, sorry but I would be embarrassed to carry that. but keep in mind im an electronics engineer. I carry a DMM (digital multi meeter)
February 28th, 2010, 9:49 am
ya DMM solves most electrical problem, for me its nice for work to power up certain componets if I need to just for a quick check. I do like chasing electrical problems in cars when they have one although most can be found in like 15min or less. From what I recall we had 2 vehicles in the last yrs that took hrs as things didnt make any sense and electrical diagrams provide with alldata and TIS were somehow not right.
Another example is for a problem with power supply with fuel pump or something like that I can lock the probe in power and run the car to bring it in the shop, makes it easier than pushing it uphill :thumb:
Cam Cam
March 8th, 2010, 9:26 pm
i gotta agree with blackbeauty on this one a power probe 3 is very handy. A DMM is obviously better for more engine type diag but that power probe is great for figuring out lights and fuel pumps and other basic stuff that needs 12v and a good ground. bassically a testlight on 'roids. i've used mine to run a fuel pump from shaverlake to fresno in the middle of the night
March 8th, 2010, 11:27 pm
jeeprolet wrote:
..... i've used mine to run a fuel pump from shaverlake to fresno in the middle of the night
:thumb: thats a perfect example
Cam Cam
March 9th, 2010, 12:01 am
my $3 roll of wire and 0.50 in aligator clips beats that. ya good basic tool I have to agree but has no place in my hands. I would recomend it to basic troubleshooters that are never ever going to upgrade to a DMM. If you plan to get /; use a DMM in the future don't waste the money... BTW you can make a test light out of a scrap 12V light socket and some wire.
March 9th, 2010, 11:50 am
opinions are like a$$holes... :lol:
March 9th, 2010, 12:44 pm
and dave's stinks!!! :goodfinger: :goodfinger: haha just kidding dave. i like using my multi meter alot too, really just depends on what i'm doing
March 9th, 2010, 1:30 pm
BTW, I continue to update my list on the front page here from time to time.
viewtopic.php?p=687#p687
Feel free to look it over, I've removed things like anti free and orange hand wash in favor of more water and biodegradable soap.
April 28th, 2010, 9:29 am
Getting ready for Dusy - no idea where to serve this as a xls anymore. (I gave up earthlink)
Check,Part,Category,Notes,,
,Anti Freeze,Fluids,,,
,Brake and parts cleaner,Fluids,,,
,Brake Fluid,Fluids,,,
,Dielectric grease,Fluids,,,
,Differential Oil,Fluids,,,
,Distilled Water 2 Gal.,Fluids,,,
,Engine oil,Fluids,,,
,Power Steering Fluid,Fluids,,,
,Silicone form a gasket,Fluids,,,
,Trans Fluid,Fluids,,,
,Transfer Case fluid,Fluids,,,
,Wheel bearing grease,Fluids,,,
,Windshield washer fluid,Fluids,,,
,Come along,Recovery Gear,,,
,High Lift,Recovery Gear,,,
,Hitch ball,Recovery Gear,,,
,Hitch Pins,Recovery Gear,,,
,Plank (For jack or to throw under tire),Recovery Gear,,,
,Rope,Recovery Gear,,,
,Shackles,Recovery Gear,,,
,Tow Chain,Recovery Gear,,,
,Tow Strap,Recovery Gear,,,
,Winch,Recovery Gear,,,
,Winch cable repair clamps,Recovery Gear,,,
,"Winch Kit (snatch block, tree saver, chain, gloves, winch controller)",Recovery Gear,,,
,Solder,Repair Supplies,,,
,Air Line,Repair Supplies,,,
,ARB line and repair fittings,Repair Supplies,,,
,Bolt and Wiring Kit,Repair Supplies,,,
,Cable ties,Repair Supplies,,,
,Carb Cleaner,Repair Supplies,,,
,Chain lengths and bolts,Repair Supplies,,,
,Duct Tape,Repair Supplies,,,
,electrical connectors,Repair Supplies,,,
,Electrical Tape,Repair Supplies,,,
,Fix-A-Flat,Repair Supplies,,,
,Penetrating Oil,Repair Supplies,,,
,Power Steering Stop Leak,Repair Supplies,,,
,Radiator stop leak,Repair Supplies,,,
,Starting Fluid,Repair Supplies,,,
,Switches toggles for bypass repairs,Repair Supplies,,,
,Taillight Repair Tape,Repair Supplies,,,
,Teflon tape,Repair Supplies,,,
,Tire Repair kit (plugs),Repair Supplies,,,
,WD-40,Repair Supplies,,,
,Wire 10 - 20 Gauge,Repair Supplies,,,
,Ham Radio and spare batteries,Safety,,,
,CB radio,Safety,,,
,Cell Phone,Safety,,,
,Compass,Safety,,,
,Daypack,Safety,,,
,drinking water,Safety,,,
,Fire Extinguisher,Safety,,,
,First Aid Kit,Safety,,,
,Flashlight,Safety,,,
,Food for one day,Safety,,,
,GPS,Safety,,,
,Matches,Safety,,,
,Notepad and Pen,Safety,,,
,Roadside emergency kit,Safety,,,
,Air Filter,Spare Parts,,,
,Air Line,Spare Parts,,,
,Alternator,Spare Parts,,,
,Axle shafts,Spare Parts,,,
,Battery cable,Spare Parts,,,
,Bead lock wheel studs and nuts,Spare Parts,,,
,Belts,Spare Parts,,,
,Distributor cap and Rotor,Spare Parts,,,
,Drive Shafts,Spare Parts,including u-joint and yokes.,,
,ECU (computer),Spare Parts,,,
,Fan or Motor,Spare Parts,fan motor.,,
,Freeze Plugs,Spare Parts,,,
,Fuel Line,Spare Parts,,,
,Fuel Line Clips,Spare Parts,,,
,Fuel Pump,Spare Parts,,,
,Fuses,Spare Parts,,,
,Heater Hoses,Spare Parts,,,
,Hose Clamps,Spare Parts,,,
,ignition coil,Spare Parts,,,
,Ignition module,Spare Parts,,,
,Kingpin parts & shims,Spare Parts,,,
,Lock out hubs,Spare Parts,,,
,Lug Nuts,Spare Parts,,,
,Oil Filter,Spare Parts,,,
,Power steering pump,Spare Parts,,,
,Radiator Hoses,Spare Parts,,,
,Relays,Spare Parts,,,
,Sector Shaft,Spare Parts,,,
,Spare Tire,Spare Parts,,,
,Spark Plugs,Spare Parts,,,
,Spring Shackle,Spare Parts,,,
,starter solenoid,Spare Parts,,,
,Steering Box,Spare Parts,,,
,steering linkage,Spare Parts,,,
,steering shaft,Spare Parts,,,
,Tie rod Ends (reamed for High steer),Spare Parts,,,
,trans filter - remote,Spare Parts,,,
,U-Joints,Spare Parts,,,
,Vacuum line,Spare Parts,,,
,wheel bearing nuts,Spare Parts,,,
,wheel bearings,Spare Parts,387A 382A SET38,,
,Wheel Studs,Spare Parts,,,
,Wiper control module and switch (or non-delay switch),Spare Parts,,,
,Yokes - axle,Spare Parts,,,
,Yokes - t-case,Spare Parts,,,
,Adjustable Wrenches,Tool box,,,
,Allen Wrenches,Tool box,,,
,Box wrenches SAE and Metric,Tool box,,,
,Breaker Bar 1/2 ,Tool box,,,
,C clamp (Compress the disc brakes),Tool box,,,
,chisel Small dull for hammering stuff apart,Tool box,,,
,Digital Multi Meter,Tool box,,,
,Gloves mechanics,Tool box,,,
,Gloves Nitrile,Tool box,,,
,Gloves Work,Tool box,,,
,hack saw,Tool box,,,
,Hammer B.F.H.,Tool box,,,
,Hammer or two,Tool box,,,
,Hammer soft face (copper),Tool box,,,
,Pitman arm puller,Tool box,,,
,Pliers,Tool box,,,
,Pliers (regular and needle nose),Tool box,,,
,Propane torch head,Tool box,,,
,Rags,Tool box,,,
,Ratchet 1/2 ,Tool box,,,
,Ratchet 3/8 ,Tool box,,,
,Safety glasses,Tool box,,,
,"Screw drivers Philips and flat head, small to large",Tool box,,,
,Snap ring pliers,Tool box,,,
,Socket Dana 44,Tool box,,,
,Socket Dana 60,Tool box,,,
,Socket Extensions / Adaptors,Tool box,,,
,Socket Gator for ratchet (amazing tool!),Tool box,,,
,Socket Impact Deep Set 1/2 SAE Metric,Tool box,,,
,Socket Impact Shallow Set 1/2 SAE Metric ,Tool box,,,
,"Socket set full, metric and SAE deep and shallow",Tool box,,,
,Socket Spark plug,Tool box,,,
,Socket Sterling,Tool box,,,
,Socket Torx bits,Tool box,,,
,Sockets Few larger SAE and metric (axle and t-case yokes etc.),Tool box,,,
,Tie Rod tool (pickle fork),Tool box,,,
,tire deflators,Tool box,,,
,Tire pressure gauge,Tool box,,,
,Torx Screw drivers,Tool box,,,
,U-Joint Tools Block oh wood and BFH will do,Tool box,,,
,Utility knife and blades,Tool box,,,
,Valve Stem repair tool,Tool box,,,
,Vice Grip,Tool box,,,
,"Wire cutter, crimper, and splicer",Tool box,,,
,Wire Strippers,Tool box,,,
,air blow gun,Tools Air,,,
,Air Compressor,Tools Air,,,
,air drill,Tools Air,,,
,air grinder,Tools Air,,,
,air impact,Tools Air,,,
,air ratchet,Tools Air,,,
,air tire chuck,Tools Air,,,
,Air Lines,Tools Big,,,
,Bolt Cutters,Tools Big,,,
,Butane Torch,Tools Big,,,
,Crescent Wrench Very Large,Tools Big,,,
,Drain Pan,Tools Big,,,
,Empty container in case I gotta drain something.,Tools Big,,,
,Funnel with tubing,Tools Big,,,
,Gas siphon,Tools Big,,,
,Gear Oils Pump,Tools Big,,,
,Glue Sticks,Tools Big,,,
,Heavy monkey wrench,Tools Big,,,
,Jack 3 Ton Bottle / Jack Stand Combo,Tools Big,,,
,Jack Bottle,Tools Big,,,
,Jack Small Floor,Tools Big,,,
,Jumper Cables,Tools Big,,,
,Lug wrench,Tools Big,,,
,portable welding supplies,Tools Big,,,
,Pry Bar large and small,Tools Big,,,
,Repair Manual,Tools Big,,,
,Tire iron,Tools Big,,,
,Axe,Trail / camping,,,
,Blankets and a warm sleeping bag,Trail / camping,,,
,Bottle opener,Trail / camping,,,
,Camera,Trail / camping,,,
,Clothes,Trail / camping,,,
,Fire wood,Trail / camping,,,
,Folding chair,Trail / camping,,,
,Hat,Trail / camping,,,
,Ice scrapper,Trail / camping,,,
,Inverter ,Trail / camping,,,
,Meals and snacks for on the road,Trail / camping,,,
,Orange hand wash,Trail / camping,,,
,Pots and Pans,Trail / camping,,,
,Shovel,Trail / camping,,,
,Silverware,Trail / camping,,,
,Stove and Fuel,Trail / camping,,,
,Sunglasses,Trail / camping,,,
,Tarp and or old blanket,Trail / camping,,,
,tent,Trail / camping,,,
,Tie downs,Trail / camping,,,
,TP,Trail / camping,,,
,trash bags,Trail / camping,,,
,WAG Bags,Trail / camping,,,
August 19th, 2014, 3:56 pm
lol thorough
August 19th, 2014, 4:50 pm
