View unanswered posts | View active topics It is currently June 24th, 2019, 3:43 am
Reply to topic  [ 160 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11
 What do you carry with you on a trip?
Post Re: What do you carry with you on a trip?
I don't have a list, it would be pretty long. I just go through everything pulling out what I need, and thinking through scenarios that did happen, or could happen. Maybe I should make a list.
Here is some of the stuff.
December 30th, 2015, 10:01 pm
A list is nice and over the years you start refining it. I've broken ball joints, but such a small items, I may forget them when I'm packing. I'm hoping to get a more permanent set of wheeling tools some day, but until then, I pack for every trip.
In refining, for example, I no longer carry antifreeze. Any water will work great getting me off the trail. When my old fan clutch failed and caused the coolant to over boil, I added water straight from Ellis creek!
December 31st, 2015, 9:43 am
My thinking on Antifreeze, if I'm in a situation where it is needed i am probably leaking fluid and i would prefer to not leak any more green stuff than the initial loss. Also if it's an overheat situation water cools better that Antifreeze anyway
December 31st, 2015, 1:33 pm
Go a step further, if you have space for 3 gals of water for you and 3 gals of antifreeze the truck. Replace with water, now in a emergency I have 6 gals of water to drink!
December 31st, 2015, 11:36 pm
This list (first post) is still indispensable for me. Last weekend I gave my coil to a guy to help him get off the trail. This weekend I used an old ujoint. Don't forget to save your used parts you change as spares in the future.
June 19th, 2016, 8:01 am
Post Re:
Truck Stuff
-Tow Strap
-Tow shackles
-Hitch pin
-Gallon of coolant, Gallon of water, Gallon of 50/50
-Engine oil
-ATF
-Gear oil
-Brake Fluid
-WD40
-Starting fluid
-Fix-A-Flat
-High Lift
-Bottle Jack
-Tire iron
-Spare Belt
-Some spare hoses
-Spare spark plug wires, distributor cap and ignition coil
-10 GA wire with miscellaneous electrical connectors
-Spare U-Joint
-Jumper Cables
-Spare starter solenoid
Tools
-Shovel
-Duct Tape
-Cable ties
-Full socket set, metric and standard, deep and shallow
-Wrenches
-Vice Grip
-Various pliers
-Various screwdrivers
-Hammer or two
-Gas siphon
-Wire cutter, crimper, and splicer
-Utility knife
-Torx bits
-Allen wrenches
-Dana 44 Socket
-Leather work gloves
Wow! That is a lot!
December 1st, 2017, 7:32 am
Update the first post again for 2018! I still haven't even add baby stuff to the list :P
August 1st, 2018, 11:13 am
- Dog
- Dog food
Cam Cam
August 8th, 2018, 2:14 pm
i can't wait to see you load all that stuff into your willy's on your next trip Justin. You might be Danny packing for Pismo for "most stuff packed per cubic foot"
August 8th, 2018, 3:28 pm
For the Jamboree on the con, I brought the same tools, but less parts. Everyone knows jeeps don’t break, so you don’t need tools!
August 9th, 2018, 8:15 am
