View unanswered posts | View active topics It is currently February 19th, 2019, 5:26 am
Reply to topic  [ 6 posts ]
 All about lug nuts!
Post All about lug nuts!
It's the little things that get you! Yesterday we found I had some loose lug nuts, and while talking to Peter and Rich, it came up what's the right lugs for these rims. I was thinking I needed mag lug but it turns out these are aluminum rims. I checked Mickey Thompson's product page and I'm already running the correct bulged acorn style lugs. http://www.mickeythompsontires.com/whee ... baja-lock/
The mag style would have used a flat washer. Good to know that I have the right lugs! I'm going to order some more because we cut the top off these when the studs were too long (before I added a spacer).
Here is a good diagram: https://images-na.ssl-images-amazon.com ... sHJvNS.pdf
July 23rd, 2017, 12:13 pm
Post Re: All about lug nuts!
The pro comp lug nuts that Peter and I run work great and are cheap. Glad we caught that issue before your tire passed by you on the mountain road.
July 23rd, 2017, 8:17 pm
I second the pro comp nuts. Good idea checking the back of the truck. Glad it worked out the way it did.
July 23rd, 2017, 9:36 pm
Thanks again for the help guys! I'm not keen non standard lug shapes, loosing the key on a trip isn't something I'm willing to risk.
July 23rd, 2017, 10:36 pm
Rich remember that time we almost lost a tire on your 91 coming back from the Con? I think 3 of 5 studs had broke!?
Agreed but to each their own.
Also I'm not sure there's enough detail in here to call it all about lug nuts :goodfinger:
July 24th, 2017, 1:50 pm
Yes Danny... it was scary... I checked my lug nuts while airing up this time
July 24th, 2017, 8:41 pm
