View unanswered posts | View active topics It is currently June 12th, 2021, 1:21 pm
Reply to topic  [ 9 posts ]
 Anyone have any experience with 3rd gen 4runners?
Post Anyone have any experience with 3rd gen 4runners?
2000-2001 to be exact. My niece's boyfriend works for CarMax and says he can get me one from auction for about $2,000-2,500. Not sure if I would turn it into a rig or just driver it, but for the price its hard to pass up.
Im not sick, but Im not well
June 12th, 2016, 12:36 pm
Post Re: Anyone have any experience with 3rd gen 4runners?
Cam has a 2001 I believe and is our resident Toyota expert so hopefully he'll chime in here.
June 13th, 2016, 6:41 am
Overall great vehicles. Get the specs on it and I can give you more info.
Usually you want a 3.4L v6 with under 180k miles, 2wd or 4wd either is ok. 5spd manual is very reliable. Auto is also reliable but if they did any kind of towing the trans does tend to run a bit hot. So use an external cooler if it doesn't already have one.
2000-2001 4WD had a push button 4wd engagement. If it was a family vehicle and only got it into 4wd once a year or never sometimes those motors can get stuck.
Motor is easy to work on, maintenance is very straight forward. Just make sure you only use denso or ngk for parts. Running some bosh or autolite plugs will make it run like crap..
ALL our customers with 4runners love them and hardly ever sell them. 95% of those are all stock daily driven with little issues. Expect 17-20 mpg highway or 250-300 a tank on highway use.
Many are getting old enough that for trail/road rigs they are getting SAS with success.
Cam Cam
June 13th, 2016, 8:16 am
Thank you. I don't have any specs since he is still looking for one. Just looking them up I see they go for over $5k so for $2k or so I thought I would jump on it. The good thing is if they get one or two in, I don't have to get if it's not what I want.
June 13th, 2016, 6:41 pm
If all possible no salvage title AND no east coast 4runner. The frame rust from the inside out, once you see the rust on the frame is too late and they don't pass inspection out there. Then they end up at auctions and dismantlers.
Cam Cam
June 14th, 2016, 9:01 am
Do the runners have the same frame issues the tacos do? I've never seen another truck fold in half due to rust like the Tacoma does. Also since he mentioned CarMax, I would think they'd do an inspection/30 day warranty so hopefully no roaches.
Really can't go wrong with any Toyota, there is a reason the hold their value so well.
June 15th, 2016, 11:38 pm
I've got a friend at work looking for one as well and thought of this...
Do these early 2000's with the 3.4 have a timing belt? And if so whats recommended change interval? How about water pumps or other things to look out for on a highish mileage 4runner, say 150k?
August 18th, 2016, 8:04 am
Yes all 3.4L have timing belt, and yes replace the water pump, thermo and drive belts at the same time. Use Aisin pump and a good belt.
Interval is 90k, if you are looking at one at 180K then the idle bearing and tensioner bearing get replaced then too.
Easy job to do and a few hours at home on a Saturday can be done. Do pick up a tensioner too, cheap on amazon or online, makes the job quicker since actually removing the tensioner can be a pain.
Cam Cam
August 29th, 2016, 10:13 am
Thanks Cam
August 29th, 2016, 3:32 pm
