View unanswered posts | View active topics It is currently June 17th, 2021, 3:47 pm
Reply to topic  [ 3 posts ]
 Looking for a ford 9" for cheap:)
Post Looking for a ford 9" for cheap:)
Anyone help out with this? It's going to cut down to fit the scout.
May 6th, 2013, 12:01 pm
Post Re: Looking for a ford 9" for cheap:)
You can go real cheap and get an early bronco one. Its upgradeable but weaker than a later full size one. You will save not having to shorten it.
Carrier,locker,gears or just slapping something in?
May 6th, 2013, 12:18 pm
I just pulled one from pick n pull last week for $205. I know there was at least one more out there when I was there, but it didn't have a dif tag so I couldn't confirm spline count. They came in a ton of vehicles, I just checked the pick n pull inventory online until I saw what I was looking for, then I went out and checked it out. http://www.fordification.com/tech/rearends_ford01.htm is a great place to make sure you know what you're looking at before you spend the time to pull the axle.
It's a Cherokee thing, a step above a Jeep thing
May 7th, 2013, 9:53 am
