View unanswered posts | View active topics It is currently June 17th, 2021, 4:11 pm
Reply to topic  [ 6 posts ]
 19 lb injector need (1) ASAP and don't want to spend $70
Post 19 lb injector need (1) ASAP and don't want to spend $70
A new one is $70 and a used ones are usually garbage. Anyone have 1 laying around? I was cleaning mine out and I have 1 that won't open.
Let me know.
May 10th, 2013, 1:31 pm
Post Re: 19 lb injector need (1) ASAP and don't want to spend $70
Is there resistance in the coil? If so let it sit in some carb cleaner and see if that'll free it up.
May 10th, 2013, 7:15 pm
I did and its working now. I'm a little sketched out on it. I'll install it where I can change it easily
May 10th, 2013, 8:20 pm
Your computer should have a cylinder balance test you can run down the line to see if that ones weak.
May 10th, 2013, 10:21 pm
I have my old injectors from the ranger at my folks house somewhere. I thought they were 19# but am not sure. You're welcome to em. Let me know- I'll be out there tomorrow for mothers day and can swoop em up, or relay them to you somehow.
I figured out how to edit my signature.
May 11th, 2013, 5:13 pm
Thats ok. Thank you buddy.
May 12th, 2013, 7:36 am
