View unanswered posts | View active topics It is currently June 17th, 2021, 4:12 pm
Reply to topic  [ 14 posts ]
 In NEED of Warn Locking Hubs Dana 60
Post In NEED of Warn Locking Hubs Dana 60
I am looking for some Warn front hubs for a 1991 Dodge Dana 60. I believe all Ford Chevy Dodge are the same. Looking for new or used in good condition. If I can't locate I'm just going to order new. Figured I would try on here 1st.
Took my 4runner for a drive to Walmart to pick up some Olive Green paint and some steaks for the BBQ when the steering wheel started going all over the place. Got to my shop and checked it out. And my WHOLE hub assembly blew up, my wheel was surprisingly still on. Their was nothing left. Wheel rubbed and grinded on my caliper the whole way back. Little to no grease and mud in there. Obviously never opened or checked for maintenance. Called the previous owner n asked. He said he never checked it. So that means I'm rebuilding it all new seals and bearings. And upgrade to Warn hubs from stock.
Let me know guys. Thanks.
-Cesar
87 4Runner on WON TONS, 38.5" tires, 5.38 gears, Exo, 22re with dual cases
July 22nd, 2014, 10:22 pm
Post Re: In NEED of Warn Locking Hubs Dana 60
Is the hub broken? I get that the wheel bearings are toast but it seems strange that the hub would break?
I wouldn't bother with a warn hub or any aftermarket hub for that matter if you're staying 30 spline. The strength gains, if any, are marginal. The 1 ton stock hubs are generally pretty strong. If you really want an upgrade go 35 spline and then get warn or yukon. I'm running the yukon 35 spline hubs and I like them a lot, they were cheaper than warn and according to yukon (of course) are stronger.
July 23rd, 2014, 7:25 am
I was planning on just staying 30 spline. Should be plenty under my 22re power (under 100hp) Plus I plan on going 40s. I shouldn't have any issue if I don't go any bigger than that. Everything inside took a shit. The hub itself is fine externally. I think there was more mud than grease in the damn thing.
-Cesar
July 23rd, 2014, 8:09 am
Wow, yeah that was due for service.
I'd just run the stock hubs for now. Should be strong enough unless you really beat on it. I also remember somewhere you mentioned chromo shafts, that'd be a good time to go 35 spline hubs as it would be a bit silly IMO to buy chromo shafts and keep 30 spline outers.
July 23rd, 2014, 5:42 pm
I can float you one stocker if you want
July 23rd, 2014, 7:22 pm
I have the stocker internal piece you can have (lost the cap but you probably have that and it probably still works)
July 24th, 2014, 6:13 am
nope its apart in the first pic on the floor. If the ford is the same then they are on the TTB D50s as well... usually all over the junk yard.
July 24th, 2014, 7:34 am
If you guys do Lmk. I can use it to at least get it all patched up and good to go. And replace it or give it back to y'all when I get another.
Text me guys. 408-205-6374. I'll be in Livermore in a few Rich of you are out in Tracy. Gonna grab Tacos. More than welcome to join. :)
And Rick. Where you living now? Alamo still?
-Cesar
July 24th, 2014, 8:07 pm
Im at work wed to sat until midnight but maybe if you doing tacos sunday I can meet you out in livermore
July 24th, 2014, 11:37 pm
Down for some Livermore tacos tonight? I just got finished up with a 9 hour dyno tuning rental day, and that was back up by yesterdays 17hour dyno tuning rental day. I am BEAT. And now about to leave. If you haven't ate and want to meet in Livermore I can meet out there. If not, another day will work. Text me if anything. You got my numner
-Cesar
July 27th, 2014, 7:48 pm
Lol you should have tried my cell phone.
July 28th, 2014, 11:57 am
where are the "good" tacos in livermore? I haven't really explored for them since I usually have them at lunch in alviso
July 28th, 2014, 1:18 pm
I text you and no response. -___-
Here you go- http://www.yelp.com/biz/consuelito-mark ... -livermore
I dont go during the day. They dont taste the same as at night, where they do them in a taco stand instead of in the kitchen.
Thursday and Sunday- 8pm-12
Friday and Saturday 8pm-1am
-Cesar
July 29th, 2014, 10:39 am
BTW I wanted to thank Rick for the internal locking hub components. I was able to get my truck back up and running and go wheeling this last weekend.
-Cesar
August 6th, 2014, 11:09 am
